Visual LISP, AutoLISP and General Customization
dcl design
11 REPLIES 11
Message 1 of 12
307 Views, 11 Replies
dcl design
Hello -
I keep running into the same problem when designing dialog boxes (in dcl,
for AutoLISP routines). I have a text_part to the left of another element,
and I can't push them tightly together (if the text_part is to the right,
they seem to be jammed together by default and there's no problem!).
I pulled some elements out of one of my dialogs to make a simple example:
test: dialog
label = "Test";
key = "title";
: row
: text_part
label = "Permanent scale:";
key = "pscaledesc";
width = 16;
fixed_width = true;
: popup_list
key = "pscalepop";
edit_width = 10;
fixed_width = true;
ok_button;
A bmp of this dialog is attached.
In this particular example the space between the text_part and the
popup_list doesn't look too bad, but I would still like to know how to push
them closer together! I've tried putting them in a narrow column, etc., but
I haven't found the trick.
Thanks -
Chuck
11 REPLIES 11
Message 2 of 12
Chuck,
Try putting:<<<<<<<<<<<<<<
: row
fixed_width = true;>>>>>>>>>>> for the row widget. That way the row should only take up as much space as needed.
Bill
Message 3 of 12
Thanks Bill, I just tried fixed_width = true; within the row in my example,
with and without width = various values.
I find that I can make the dialog wider with a large value for width, but it
won't get any narrower than it already was.
There's got to be some trick to pushing these tiles together. I even tried
putting them in separate columns and giving the columns fixed widths. So
far, nothing works. This problem has plagued me for years!
Chuck
BillZ wrote in message
news:f10a2fc.0@WebX.maYIadrTaRb...
Chuck,
: row
Bill
Message 4 of 12
Chuck,
I can't see the BMP that you posted.
I know the dialog label requires a certain amount of space at the top of the dialog box. This can determine how "narrow" you can get the main box to become.
Can you email me the BMP?
Bill
Message 5 of 12
On second try, I think you have run into a limitation of DCL that is an annoiance. Unless someone else can make me look like a Fnark and come up with a way to do it, I would say it can't be done.
Bill
Message 6 of 12
If so, I guess I'll have to keep limping along making dialogs with an excess
of whitespace between descriptions and the other tiles to their right. I
just wonder how dcl decides how big to make that space.
Thanks for giving it some thought.
news:f10a2fc.3@WebX.maYIadrTaRb...
Message 7 of 12
Chuck
put the text in a column and right justify it,
you can use text too...or
can mix with paragraphs etc,
test: dialog
label = "Test";
key = "title";
: row
: column {
: text_part
key = "pscaledesc";
width = 16; alignment=right;
fixed_width = true;
: popup_list
key = "pscalepop";
edit_width = 10;
fixed_width = true;
ok_button;
HTH
matk
"Chuck Wheat" wrote in message
news:3F6217D41E32CC716A5499F5DD87CD2D@in.WebX.maYIadrTaRb...
> Hello -
element,
> test: dialog
> label = "Test";
> key = "title";
> : row
> : text_part
> key = "pscaledesc";
> width = 16;
> fixed_width = true;
> : popup_list
> key = "pscalepop";
> edit_width = 10;
> fixed_width = true;
> ok_button;
push
but
> Thanks -
> Chuck
Message 8 of 12
can do some refinements ...
was this what you were looking for?
test: dialog
label = "Test";
key = "title";
: row
: column { spacer_0;
: text
key = "pscaledesc";
fixed_width = true;
: popup_list
key = "pscalepop";
edit_width = 10;
fixed_width = true;
: spacer { height=1;}
ok_button;
> Hello -
element,
> test: dialog
> label = "Test";
> key = "title";
> : row
> : text_part
> key = "pscaledesc";
> width = 16;
> fixed_width = true;
> : popup_list
> key = "pscalepop";
> edit_width = 10;
> fixed_width = true;
> ok_button;
push
but
> Thanks -
> Chuck
Message 9 of 12
I had gotten as far as your first post (ie right aligning the text), but
hadn't figured out how to push the text down ... thanks. Only thing is, the
extra whitespace is still there, just moved over to the left of the text.
There would be times when this would work, like if the text and edit box
were both to the right of something else, and the text didn't need to align
with anything above and below it.
It's probably worth noting that if you give the edit box an equivalent label
rather than placing text next to it, you get the same excess whitespace:
test: dialog
label = "Test";
key = "title";
: popup_list
key = "pscalepop";
edit_width = 10;
fixed_width = true;
ok_button;
Too bad it doesn't work to just put it in a column and give the column a
fixed width to squeeze them together! It sure sounds like it should work
Message 10 of 12
Chuck
i have found out by experience, there is always a way,
maybe not what you expect, but something similar...
and sometimes nicer. try the code below, remove the
label and add the following to your lisp code...
(set_tile "pscaledesc" "Permanent scale:")
BTW the spaces are sometimes necessry, but if you
realy have to, you can try to concatenate text_parts
without spaces.
mark
test: dialog { label = "Test"; key = "title";
: spacer { height=0;}
: row { alignment=left;
: column { alignment=top; fixed_height=true;
: spacer {height=0; }
: text_part { // label = "Permanent scale:";
key = "pscaledesc"; width=14; alignment=right; } }
: popup_list { key = "pscalepop"; edit_width = 10;} }
: spacer { height=0.5;} ok_button; }
news:7456305B21088252D6F242A485091994@in.WebX.maYIadrTaRb...
the
align
label
> test: dialog
> label = "Test";
> key = "title";
> : popup_list
> key = "pscalepop";
> edit_width = 10;
> fixed_width = true;
> ok_button;
Message 11 of 12
Fabulous! I'm attaching another bmp for anyone that might follow this
thread. It was generated with this code:
test: dialog
label = "Test";
key = "title";
: row
: text_part
{ // label = "";
key = "pscaledesc";
width=14;
fixed_width = true;
: popup_list
key = "pscalepop";
// label = "";
edit_width = 10;
fixed_width = true;
ok_button;
Notice that I took the right alignment and spacer out and it still works.
Having to drive the text tile is no problem at all because half the time I
do it anyway. Thank you very much indeed for digging into this!
Message 12 of 12
Chuck
you are welcome...
you might have to keep the right alignment...
because as soon as the text is something
shorter than "Permanent Scale:" then you will
find yourself same place you started last year...
the width=14 is controlling the size... but i guess
you know enough now to manipulate anything.
mark
news:E2BF55AD3FA89567C0F50AF9CDA32DA2@in.WebX.maYIadrTaRb...
> test: dialog
> label = "Test";
> key = "title";
> : row
> : text_part
> { // label = "";
> key = "pscaledesc";
> width=14;
> fixed_width = true;
> : popup_list
> key = "pscalepop";
> // label = "";
> edit_width = 10;
> fixed_width = true;
> ok_button;
”Boost
