Change all block element to Layer 0 without changing color, linetype
25 REPLIES 25
Message 1 of 26
pixelarch
29672 Views, 25 Replies
Dear All,
Please find the attached. I have too many blocks with specific layers inside.
Could you help me to develope lisp can change all to layer 0 but keep color and linetype as it is.
I will use this as a part of script to change multiple block.
25 REPLIES 25
Message 21 of 26
Sujan.Maharjan
in reply to: Lee_Mac
Hi lee,
Can i have option to change the Colors/linetypes to By Block/By Layer?
"Revit Lies in the tension between what we want to do and what can be done!"
Message 22 of 26
kpblc2000
in reply to: Sujan.Maharjan
http://forum.dwg.ru/showthread.php?t=21492 (eng: https://translate.google.ru/translate?sl=ru&tl=en&js=y&prev=_t&hl=ru&ie=UTF-8&u=http%3A%2F%2Fforum.d... )
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Алексей Кулик aka kpblc | Aleksei Kulik aka kpblc Facebook | LinkedIn
autolisp.ru
Техническая поддержка программистов Autodesk в СНГ
Библиотека пользовательских lisp-функций | Custom Lisp-function library
Message 23 of 26
This is great code!  Is there a way to make it so you can select an entire drawing and apply the routine to ALL blocks?
Message 24 of 26
@daviddangelantonio wrote:
....  Is there a way to make it so you can select an entire drawing and apply the routine to ALL blocks?
The link in Post 11 should do that for you.
Kent Cooper, AIA
Message 25 of 26
IB55
Lee_Mac
I try to use your script but I am getting:
error: no function definition: LM:APPLYTOBLOCKOBJECTS
What I am doing wrong?
Your help is much appreciated
Message 26 of 26
Ranjit_Singh2
in reply to: IB55
You need to have LM:ApplytoBlockObjects loaded before running c:test. Go to his website and you can find the function there.
”Boost
