i have a little Problem here.
What i want to do is popluate a Listbox with with the area of previously selected Objects.
This is what i have at the moment:
i = 0 ListBox1.ColumnCount = 2 For Each ssetOBJ In sset objarea = ssetOBJ.Area i = i + 1 With ListBox1 .AddItem .List(.ListCount - i, 0) = "Fläche" .List(.ListCount - i, 1) = objarea End With Next
But the code only writes the area of the last Object in the first Row of the Listbox.
I think in the FOR EACH Expression the variable "i" pass always "1" for the Row Number.
Anyone knows why?
Thx for Help.
Solved by Hallex. Go to Solution.
You need to use 2 column listbox,
so you may want to use this code
just very basic though, change to suit
Private Sub CommandButton1_Click() Me.Hide Dim oSset As AcadSelectionSet Dim oEnt As AcadEntity Dim fcode(0 To 1) As Integer Dim fData(0 To 1) As Variant Dim dxfcode, dxfdata Dim i As Integer, j As Integer, n As Integer, m As Integer, k As Integer Dim setName As String fcode(0) = 0 fData(0) = "LWPOLYLINE" fcode(1) = 70 fData(1) = 1 dxfcode = fcode dxfdata = fData setName = "$PolyLines$" '// make sure the selection set does not exist For i = 0 To ThisDrawing.SelectionSets.Count - 1 If ThisDrawing.SelectionSets.Item(i).Name = setName Then ThisDrawing.SelectionSets.Item(i).Delete Exit For End If Next i Set oSset = ThisDrawing.SelectionSets.Add(setName) ' oSset.Select acSelectionSetAll, , , dxfcode, dxfdata oSset.SelectOnScreen dxfcode, dxfdata ' loop all polylines ReDim dataArr(oSset.Count - 1, 0 To 1) For n = 0 To oSset.Count - 1 Dim cEnt As AcadEntity Set cEnt = oSset.Item(n) Dim intPoints() As Variant Dim oPline As AcadLWPolyline Set oPline = cEnt Dim ar As Double ar = oPline.Area Dim lyr As String lyr = oPline.Layer dataArr(n, 0) = ar dataArr(n, 1) = lyr Next n oSset.Erase ListBox1.Clear ListBox1.ColumnCount = 2 ListBox1.ColumnWidths = "3cm;4cm" ListBox1.ColumnHeads = True ReDim layArr(0 To UBound(dataArr, 1), 0 To 1) As Variant For i = 1 To UBound(dataArr, 1) layArr(i - 1, 0) = dataArr(i - 1, 0) layArr(i - 1, 1) = dataArr(i - 1, 1) Next i ListBox1.List() = layArr Me.Show End Sub
Very nice and clean code. Thx for Helping me out.
So i dont posted all my code.
I have found a Solution by myself.
I will post the code and the Solution that i found here as soon as possible.
