Figured it out, Thanks.
AcadEntity works with FIELD. Thats what I was looking for. Got my code
working now.
Have a great week,
Dan
"Dan" wrote in message
news:415982b6$1_2@newsprd01...
> I understand how to truncate text to get what I want from the text string,
> but I have not figured out how to get the string from the field yet. I
know
> how to get the field expression.
> I must be overlooking something:
> Sub CaptureFieldText()
> ' Create the selection set
> Dim ssetObj As AcadSelectionSet
> Dim point(0 To 2) As Double
> Dim fText As AcadText ' Not
> sure if this is the right object for the field
> Dim sysVarName As String
> Dim sysVarData As String
> sysVarName = "CTAB"
> sysVarData = "Model"
> ThisDrawing.SetVariable sysVarName, sysVarData
> Set ssetObj = ThisDrawing.SelectionSets.Add("capField")
> point(0) = -100: point(1) = 525.221859: point(2) = 0
> ssetObj.SelectAtPoint point
> For Each fText In ssetObj
> 'Here is where I wanted to place code to extract string from field
> Next fText
> ThisDrawing.SelectionSets.Item("capField").Delete
> Set Layout = Nothing
> Set fText = Nothing
> End Sub
> Any help is appreciated. I am sure there are better habits, and coding
could
> be optimized, flame awway.
> I am still very new at this,
> Thanks,
> Dan
> "Ed Jobe" wrote in message
> news:415878f2$1_1@newsprd01...
> > Use the TextString property to get what was evaluated. If there is other
> > text besides the field, use the standard string manipulation functions
> (e.g.
> > InStr) to extract the field info from the TexString.
> > Ed
> > news:41586a3f_3@newsprd01...
> > > I have learned how to create a field in VB using the Object Id, but I
am
> > > struggling with how to extract the string itself from a field, place
it
> > into
> > > the clipboard, to be copied into another application (Excel).
> > > Thank you,
> > > Dan
