Hey all,
I am Using a Windows 7 based x64 system I am working on AUTOCAD 2010 with VBA 6 but i am getting teh error "Runtime Error 429 : ActiveX Component Can't Create Object " .
I started doing this project on a 32 bit system and it worked fine .But , since i moved to 64 bit system,I get this error whenever i execute a subroutine that has to creat something in AUTOCAD.Please see the code of related module below.
I have tried Autocad 2011 also but problem does not solve.
Would appreciate your help a lot .
Best Regards,
Irfan
'-------------------------------- '' RANDOM WALK '-------------------------------- ' Global Data ' random step Private Type RStep L As Double ' step length a As Double ' absolute step angle m As Double ' mass value x(2) As Double ' step position (x,y,z) End Type ' input data Dim start(2) As Double ' starting coordinates x,y,z Dim LRnd(1) As Double ' specification of the random length ' (0): mean value / (1): amplitude Dim ARnd(1) As Double ' specification of the random angle Dim MRnd(1) As Double ' specification of the random mass Dim Steps As Integer ' number of steps Dim RSteps() As RStep ' array of RStep-items ' Input Data ' setup the input data for the walk Sub SetInputData() ' setup the starting point start(0) = 0# start(1) = 0# start(2) = 0# ' setup the random length LRnd(0) = 100# ' mean value LRnd(1) = 20# ' amplitude ' setup the random angle ARnd(0) = 30# ARnd(1) = 180# ' setup the random mass MRnd(0) = 1# ' 1 kg MRnd(1) = 0.4 ' number of steps Steps = 100 End Sub ' Calculate the data for the step i ' i range from 1 to Steps Sub GetStep(i As Integer) ' Error Check If i < 2 Then Exit Sub ' lower bound check If i > Steps Then Exit Sub ' upper bound check ' calculate the new absolute angle RSteps(i).a = RSteps(i).a + RSteps(i - 1).a ' calculate the step position degrad = Atn(1) / 45# RSteps(i).x(0) = RSteps(i).L * Cos(RSteps(i).a * degrad) RSteps(i).x(1) = RSteps(i).L * Sin(RSteps(i).a * degrad) ' calculate the absolute position RSteps(i).x(0) = RSteps(i).x(0) + RSteps(i - 1).x(0) RSteps(i).x(1) = RSteps(i).x(1) + RSteps(i - 1).x(1) ' calculate or initilize the z - coordinate RSteps(i).x(2) = 0# End Sub ' Main routine: Random Walk Sub randomwalk() Dim i As Integer ' setup input data Call SetInputData ' initializing the random generator Call Randomize ' setup the used memory ReDim RSteps(1 To Steps) ' initialization RSteps(1).L = 0# RSteps(1).a = 0# RSteps(1).x(0) = start(0) RSteps(1).x(1) = start(1) RSteps(1).x(2) = start(2) ' create a new log file Call InitLog(1) ' print a header section s$ = " i L A x y z M" AppendLog (s$) s$ = "---------------------------------------------------------------------------" AppendLog (s$) ' calculate the next steps For i = 2 To Steps ' next step length RSteps(i).L = LRnd(0) + (Rnd * 2# - 1) * LRnd(1) ' next angle: relative angle! RSteps(i).a = ARnd(0) + (Rnd * 2# - 1) * ARnd(1) ' next mass RSteps(i).m = MRnd(0) + (Rnd * 2# - 1) * MRnd(1) ' calculate the data for the next step Call GetStep(i) ' list the new values s$ = Format(i, "000") + formatdouble(RSteps(i).L, 12, "0.00") _ + formatdouble(RSteps(i).a, 12, "0.00") _ + formatdouble(RSteps(i).x(0), 12, "0.00") _ + formatdouble(RSteps(i).x(1), 12, "0.00") _ + formatdouble(RSteps(i).x(2), 12, "0.00") _ + formatdouble(RSteps(i).m, 12, "0.000") AppendLog (s$) Next ' plot the path with Autocad Line Objects Call plotpath MsgBox "Rand Path created!", vbInformation, "Info" End Sub ' plot the path of the Random Walk Sub plotpath() ' create a new instance of a true type color object Dim Color As New AcadAcCmColor ' color array of rgb-values Dim c(2) As Integer c(0) = 45 ' red c(1) = 155 ' green c(2) = 255 ' blue ' reset the modelspace Call resetmodelspace ' create line objects and spheres For i = 2 To Steps ' Startpoint Endpoint Set line = ThisDrawing.ModelSpace.AddLine(RSteps(i - 1).x, RSteps(i).x) Call Color.SetRGB(255, 0, 0) line.TrueColor = Color ' create a new mass instance Set m = New Mass ' and call it's create function If Not m.create(RSteps(i).m, RSteps(i).x, c) Then AppendLog ("*** Error: Sphere " & i & " can not be created!") End If Next End Sub
