VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
change Polyline.width in VBA
3 REPLIES 3
2798 Views, 3 Replies
Hi
I want Change 2000 PolyLine width Like this :
PolyLine.Width = PolyLine.Width + 1
PLEASE write me a VBA code to do that
3 REPLIES 3
arcticad
{code}
Sub plineWidth()
For Each item In ThisDrawing.ModelSpace
If TypeOf item Is AcadLWPolyline Then
item.ConstantWidth = item.ConstantWidth + 1
End If
Next
End Sub
{code}
(defun botsbuildbots() (botsbuildbots))
Hi
Thanks very much for ur Response
But My exact Problem is this:
Status is :
1- there are several thousand polyline in my drawing
2- and i defined an object data named "CODENOS" and obgect data field named "ADDRESS" (type is character) and attached to that
polylines
What i want to Do is like This:
1- User select several polylines
2- And by running a VBA macro I want take place under below event :
Dim Pline as ACADLWpolyline
For each object in selected Area
If Type of Object is ACADLWpolyline
Object.Hyperlink. = Object.ObjectData(CODENOS).Field(ADDRESS).value
End if
Next
WHAT IS EXACT VBA Code For up mentioned pesudo code ?
Sincerely
{quote}
{quote}
Search the group for 'filtered selection set' - many examples of creating
one and
iterating through it. There are also samples right in the help menu. If you
have a problem with the code post it back and someone will gladly help you.
Also search on 'SelectOnScreen' which should get you close to the proper
selection set type.
wrote in message news:6241992@discussion.autodesk.com...
Hi
”Boost
