Customize every grid
Please add the ability to customize every existing grid in Vault Explorer (rename, change state, etc...).
Thanks in advance.
7 Comments
Hi all
We use 2014 Sr1 Sp2 so this might already been implemented in 2015 or 2016.
The list/grid in the Change State dialog seems to be static. Is it possible to make it customizable like most other lists in Vault Explorer?
Cheers
Tore
This idea was actually a duplicate of
http://forums.autodesk.com/t5/vault-ideastation/customize-every-grid/idi-p/5711732
Cheers
Tore
smilinger
Agree. Just think how many dialogs with grid there are in vault, make them consistent will be a great improvement of user experience.
YounesYammouri
Status changed to: Accepted
Senthil_Kumar
@xavier_dumont2
With Vault 2023 Release, Columns in the following dialogs are customizable.
Change State Dialog, Change Revision, Change Category, Pack and Go, Synchronize Properties, Undo Check Out.
So are you ok to change this idea to implemented? Rename wizard is still pending - https://forums.autodesk.com/t5/vault-ideas/customize-rename-wizard/idi-p/6333651
xavier_dumont2
@Senthil_Kumar Yes for sure, thanks a lot for this improvement 🙂
Senthil_Kumar
Implemented in 2023 Release
