We use the Vault web client for staff that only need to view and print drawings.
The page length is limited to 25 rows with more pages to display files in batches of 25.
Can I increase the page length to more than 25?
If I can, is there a maximum number of rows I can go to?
Increasing the number of rows per page will help win user acceptance of this way of accessing files.
Oh pity, I was hoping someone could point me in the direction of where in the HTML code I could tweak a value to change the 25 row page limit. (I couldn't find anything obvious on me first examination)
Currently the fact that 'pages' are displayed rather than a continuous list (as in Vault) is being used as a reason why it's regarded as 'unusable' by certain areas within the company.
According to the Janus.Web.GridEX v3.xml -
<member name="P:Janus.Web.GridEX.GridEXPageNavigatorSettings.PageSize">
<summary>
Gets or sets a value indicating the number of rows to display per page.
</summary>
</member>
Would this enable the rows per page to be modified???
(This 'rows per page' is a real hot potato at work!!)
Hello, petercharles! I'm the developer of Vault Web Client.
I'm sorry to tell you that you're not able to modify the page size.
For now, the PageSize property you found in Janus.Web.GridEX v3.xml is assigned to be 25 by force in code behind. We can change it to be configurable if a requirement is raised.
Well, the requirement is now raised 🙂
Any timescale for this trivial modification?
Would appreciate being able to set the number of rows per page ourselves (through the xml ?) rather than preset options.
We will try to make the change as soon as possible. Please stay tuned. The setting probably would be in web.config, looks like:
<appSettings>
<add key="PageSize" value="25" />
</appSettings>
has this been changed yet? the Web client is in dire need of customisation options! for example why can't I move the frames around? I can't even read the full folder names on the left hand side of the page!
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
The "Page Size" discussed in this thread is not about the frames, it is to define how many rows to display on the grid.
Crisco
I'm well aware of that, i raised a second issue! but you didn't answer the intial part of my post either..... I can only assume the feature to increase the number of rows wasn't added in the 2012 web client!
Scott Moyse
The feature to increase the number of rows is added in the 2012 web client, but the frame size isn't.
Crisco
cool, can you direct me and others who read this where that is set please? I haven't been able to find it
Scott Moyse
As I mentioned in a previous post of the thread, the setting is in web.config:
<appSettings>
</appSettings>
thankyou, in your previous post you said, 'would probably be in'! So you posted it before the change had been made. Hence why i asked the question!
Scott Moyse
Is it possible to add the horizontal scroll, to scroll through the colums. Right now colums resizes automatically which make it extremely difficult if I want to display more properties in the main view.
It's a good idea and maybe doable. Please communicate the requirement to your reseller or product support.
