Hi all
Having some trouble with VDS 2018/2018.1, if we use 'Replace With Copy incl. Drawing' in an assembly.
Some times the assembly get wird and says that 'A Later Version have been saved'
If I tried to use Save Copy AS, I get this issue with old files.
Workflow demo in Inventor 2018.2 >> Vault 2018.2 >> VDS 2018.1
Hope someone have an idea was is going wrong.
Solved by gandhey. Go to Solution.
Do you have some errors in the log file located at c:\temp\datastandard4Inventor.log?
If so, can you post it here?
Wangdu
Hi
I have attaches the log file and a recording of the work flow.
I am able to reproduce the issue what you are facing.
It certainly looks like a bug and hopefully Autodesk will consider to address it.
However, I have found a workaround that already exists for this issue. I have tested it and it works.
To summarize here, the workaround is to
Hope it helps!
Wangdu
coolOrange
hi
I've tested the solution but still experiencing problems. Please see the video and log file.
Will you be willing to share your files (non-confidential) so that I can try to reproduce it on my machine?
Wangdu
I am able to reproduce the issue and the workaround is not helping using the files that you have sent.
So, it might be best if you contact Autodesk support in order to have them fixed it in the next version or so.
Wangdu
coolOrange
Hi
Thanks for testning it!
I will report it to Autodesk Support, an hope they can make a quick fix.
Hi Rasmus,
We're experiecing exactly the same problem.
Did you get any answer from Autodesk?
Note, this issue is fixed with Vault Data Standard 2018.2 Update.
regards,
Yogeshwar
(Vault team)
Please see the download here:
regards,
Yogeshwar
