Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
PS 2009 - Restore backup
2 REPLIES 2
marek123
299 Views, 2 Replies
Hi!
I’ve got customer who use Productstream 2009.
Software environment:
Windows 2003 Server + SP2
MS SQL 2005 Standard + SP2
Until last week system working well but the customer need to move database files (mdf) to another drive.
I propose to do it through backup and restore vault to new location.
First I make backup and restore on test machine (Win2003 Server R2 + SQL 2005 Standard SP2) – restore was successful.
After this test I proceed to make restore to production server. I tried several times. All the time restore was failed.
I make uninstall ADMS and SQL Server and install again – nothing changes.
Finally I make fresh install of Windows Server 2003 SP2 – NOTHING CHANGES!?
ADMS log:
2013-08-21 08:27:35 POSTP PRZYWRACANIA: Za pomoc konsoli serwera zestaw kopii zapasowej jest obecnie przywracany. Prosz czeka...
2013-08-21 08:27:35 ==================================================================
2013-08-21 08:53:15 Przywracanie baz danych... 0/17
2013-08-21 08:53:18 Przywracanie baz danych... 1/17
2013-08-21 08:53:18 Przywracanie baz danych... 2/17
2013-08-21 08:59:18 *******************************************************************
Ostrzeenie: Cofanie przywracania.
Wyjtek: Timeout expired.  The timeout period elapsed prior to completion of the operation or the server is not responding.
RESTORE DATABASE is terminating abnormally.
10 percent processed.
20 percent processed.
30 percent processed.
40 percent processed.
50 percent processed.
60 percent processed.
70 percent processed.
80 percent processed.
90 percent processed"
In attachment log file from SQL.
regards
Marek
Regards
Marek
2 REPLIES 2
paul.gunn
in reply to: marek123
The restore operation is taking longer than your configured database timeouts - resulting in the error. I'd recommend increasing the timeout values in web.config to avoid this problem. The advanced configuration guide has a section on how to do this (page 53) : http://images.autodesk.com/adsk/files/2009_2010_advanced_configuration_guide.pdf . I believe the 'longcommand' timeout should be the one used in restore .
Hope this helps,
Paul
marek123
in reply to: paul.gunn
Hi!
Paul, thank You. Probably this is the solution. The backup is really large – filestore has ca 170GB.
Now restoring is in progress… I’II give info when finish.
Regards
Marek
Regards
Marek
