Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
New Vault Library
7 REPLIES 7
Message 1 of 8
442 Views, 7 Replies
New Vault Library
What is the process for adding a new Library to Vault ?  The library must be located on the Server.  I have created one, but now the copy design feature does not work.  I get a HRESULT 0x8000040005 error .
7 REPLIES 7
Message 2 of 8
JamesMcMullen
Are you trying to populate the new library with copy design?  Does copy design fail all the time or in the context of certain files or libraries?  Adding a new library to the vault depends on the library.  There is a process for importing an already existing one and there is a process for creating an empty one.  Here is a link to the wiki that might help you out:
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0097-Administ97/0098-Autodesk98/0109-Manage_C109
-Jim
James McMullen
Principal SQA Eng.
Message 3 of 8
I am creating a new library.  It is after the library was created that copy disign does not work.  I am not using copy design to populate the library.  I use copy design to copy an existing project to reuse elswhere.
Message 4 of 8
JamesMcMullen
Interesting...  Can you tell me what version of Vault you are using so I can attempt to reproduce the problem here?  Also, what type of OS are you using?
-Jim
James McMullen
Principal SQA Eng.
Message 5 of 8
It is version 2010 standard.
Message 6 of 8
JamesMcMullen
I am not quite sure on what version 2010 standard means.  Is that Vault 2010 (Basic), Vault 2010 Workgroup, Vault 2010 Collaboration, or Vault 2010 Professional?  Also, what OS are you using?  I am assuming you mean Vault 2010 (Basic) and are probably running Windows 7.  But, I want to double check.
Jim
James McMullen
Principal SQA Eng.
Message 7 of 8
in reply to: JamesMcMullen
It is Vault Basic - Windows 7 64.
Message 8 of 8
JamesMcMullen
Thanks...  I will attempt to set aside time today to create the environment and attempt to reproduce the issue.
-Jim
James McMullen
Principal SQA Eng.
