Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Life Cycle Definition
6 REPLIES 6
CAD-One
638 Views, 6 Replies
I noticed that I cant delete a used lifecycle definition. I opt out the part/drawing to a None lifecycle but still cant find that we cant delete a life cycle definition.
I understand that somewhere high up in the history tab, an old version might have used that lifecycle. Is there a way to getrid of it? I dont want users to use it anymore.
Is there a solution?
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
6 REPLIES 6
mikel_martin
in reply to: CAD-One
You can not delete if a previous revision of a file used this Lifecycle.
However, you can remove it from all the categories and no user will be able to apply it to future files.
Mikel Martin
User Experience Architect
Autodesk, Inc.
CAD-One
in reply to: mikel_martin
Mikel,
  1. I went to edit mode of the lifecycle definition. Right under the title I see a categories dropdown. Currebtly I had engineering selected. I unchecked that, applied, saved & exit. Is there any other place I should look?
  2. Also, now that this life cyle will not be available for use, for the files that are already in this cycle, Can I assign to opt out (None) & then change the life cycle to new one?
C1
AutoCAD 2020
mikel_martin
You can change what category a LC is assigned to with the workflow you describe or you can go to the Categories dialog and change it there. Both have the same result.
You dont have to change a file to None before switching it to another Lifecycle def.
You can change to any Lifecycle assigned to the files category. A category may have more than one lifecycle assigned.
You may change the Lifecycle that a file is assigned to in the Change State command.
Hope this helps.
Mikel Martin
Autodesk, Inc.
CAD-One
Thanks a lot
C1
AutoCAD 2020
scottmoyse
CAD-One you shoudl use the accept as solution if this has been resolved. It helps other people later on when searching the forums for solutions
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
CAD-One
Scott, thanks for prompting. 🙂
C1
AutoCAD 2020
