Show only
Search instead for
We have typically only filled out Iproperties and used those as the searchable fields in vault. ls it possible to search the "property fields" in Field Text?
If I understand the question right, yes. But it may depend on what version and level of Vault you are using. Next to the search window you should see a small circle with 2 arrows in it.
If you select this it will open an enhanced search. From here you can add properties that you would like to search.
