We are gong to be converting from network to single user licenses soon. I have a service account for our Vault job processor computer. The service account is not an actual user account and does not have an email account.
Do I need to account for a single user Vault and Inventor license for my job processor?
Please let me know. Thanks in advance for any information you can provide.
Thanks!
Solved by ihayesjr. Go to Solution.
"Each Job Processor running headless, for the sole purpose of automation, on a machine that is not being used by an authorized user, that Job Processor needs a unique Autodesk ID assigned to that machine."
Vault 2021 Help: Licensing (autodesk.com)
The Job Processor uses Inventor Server not full Inventor so an Inventor license is not required.
Hey @ihayesjr,
My current setup I have assigned Product Design & Manufacturing Collection and Vault Professional license to job processor service account. We use publishing from ACAD Mech (AutoCAD Core Console), Plant3D and Inventor 2022.
Can I only assign the Vault Professional license only?
And
@jweiss1313
Currently I am having an issue with job processor idle time. If I set the waiting time too low, will it affect the current job that is in processing, and will it consume more resources on the system?
The Job Processor only needs the Vault Professional license.
You need an AutoCAD - including specialized toolsets license at the job processor if you're prpcessing Autocad dwg files.
You do not need an AutoCAD license to process AutoCAD DWG files.
The Job Processor uses DWG Trueview to process AutoCAD DWG files.
Vault 2023 Help | Troubleshooting Job Processor | Autodesk
What software does Job Processor use?
Custom jobs may need additional applications. See the online help for complete job type requirements.
True, but only for creating dwf. For other jobs you need an Autocad license.
What other Jobs? Synchronize Properties and PDF creation will also use DWG Trueview.
Mainly custom jobs I would say. Updating released by in drawing when releasing a dwg for example.
@ShubhamRaturi, you can set the idle time as low as you want. The jobprocessor finishes one job before it takes on next.
Updating a property or the Vault Revision table inside of an AutoCAD DWG using the Synchronized Properties job which uses DWG TrueView. These are all out-of-the-box jobs.
If you created your own custom Jobs that can't use DWG Trueview, it may require AutoCAD.
