Hi all,
I've a problem with the UpdateFileProperties function.
This function work correctly if a file in CheckedOut.
In my customization I would do the following steps:
1) Update in Vault my file with the functuion UploadFilePart and AddUploadedFile (it's the first time). After these functions the file is CheckedIn.
2) UpdateFileProperties on this file (in this moment UpdateFileProperties fail)
Is there a solution or a work around to my problem?
Thank's
Michele
Hi there - You have two options for updating properties in Vault:
//Option 1: Programmatically check out the file, update properties and check the file //back in m_serviceManager.DocumentService.CheckoutFile(vaultedfile.EntityIterationId, Autodesk.Connectivity.WebServices.CheckoutFileOptions.Master, Environment.MachineName, localFile.FullName, "Update file properties", out byteArray); //Build your property definition id and property definition values arrays here m_serviceManager.DocumentService.UpdateFileProperties(new long[] { fileMasterId }, updatePropDefIds.ToArray(), updatePropDefValues.ToArray()); //Notice the fileAssocArray that should be captured and used on check in or the file will be checked back into Vault without any file associations. m_connManager.FileManager.CheckinFile(vaultedfile, "Updated file properties”, false, fileAssocArray.ToArray(), null, false, null, Autodesk.Connectivity.WebServices.FileClassification.DesignDocument, false, filepathAbsolute); //Option 2: Use the “IExplorerUtil” to update properties //This option does not require you to check the drawings out first. public void OnLogOn(IApplication application) { iExplorerUtil = ExplorerLoader.GetExplorerUtil(application); } Dictionary<PropDef, object> propsDictionary = new Dictionary<PropDef, object>(); PropDef[] propDefFileInfoArray = m_serviceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE"); PropDef propDef = null; propDef = propDefFileInfoArray.First(n => n.Id == (long)”<prop id to be updated>”); propsDictionary.Add(propDef, "Test Entry"); iExplorerUtil.UpdateFileProperties(maxFile, propsDictionary);
Both options are better documented in the VaultSDKXXX.chm file and on Doug Redmonds blog http://justonesandzeros.typepad.com/
Thank's Jeff..
I try to use iExplorerUtil.UpdateFileProperties but call an Exception.
I think there is a problem with 64 bit system. I try to use x86 compiler configuration but it's the same.
Have you any idea?
Thank's
Michele
Your application needs to checkout the file before it can call the DocumentService.UpdateFileProperties method, and it should checkin the file afterwards. Downloading & uploading the file is optional. There is no way around the checkout/checkin.
The iExplorerUtil.UpdateFileProperties will do the checkout & download for you (it may only do this if it isn't already checked-out/downloaded), and it definitely does the upload & checkin afterwards. In between it is not only updating file UDPs, but it also gets any mapped properties from the server and writes those into the file before uploading it.
If you are looking to "sync properties" with the server then the iExplorerUtil.UpdateFileProperties is probably the way to go.
However, if you are just trying to edit some property values, then it is way overkill. Worst case is you change a value that is mapped back to content source property, which results in the file having property compliance warnings until the write-back occurs.
-Dave
