Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Prevent Event from triggering
2 REPLIES 2
amitnkukanur
387 Views, 2 Replies
Greetings..
Currently i am in a project that deals with lifecycle state's. Though this project i had done long time ago, but now again redoing.
The problem is if user triggers the lifecycle state change, is there any way to halt the event triggered. Earlier i did project that happen to work when life cycle state is changed.
Now if user changes state from Work in Progress to Released, i dont want to go to released state and come back to Work in Progress, i am trying to fit a application between two states which allows to go to released state or bounce back to Work in Progress. Any inputs will be helpful.
Cheers,
Amit
Senior Software Engineer
2 REPLIES 2
orbjeff
in reply to: amitnkukanur
Read Doug Redmond's blog called "Solving the The Four Eyes Problem". This should give you everything you need.
http://justonesandzeros.typepad.com/blog/2011/05/solving-the-four-eyes-problem.html
The quick answer is that you can add an event handler for the state transition:
DocumentServiceExtensions.UpdateFileLifecycleStateEvents.GetRestrictions += newEventHandler<UpdateFileLifeCycleStateCommandEventArgs>(UpdateFileLifecycleStateEvents_GetRestrictions);
Inside this method you can evaluate the "To" state and add a restriction if you don't want the state transition to proceed.
LfCycState toState = m_serviceManager.LifeCycleService.GetLifeCycleStatesByIds(new long[] { e.ToStateIds[i] }).First();
if (toState != null && toState.ReleasedState.Equals(true))
e.AddRestriction(new ExtensionRestriction(maxFile.Name, " The transition has been blocked"));
Your code will execute in the "UpdateFileLifecycleStateEvents_GetRestrictions" method before the transition occurs.
Jeff Johnson
Technical Consultant
MasterGraphics Inc.
amitnkukanur
in reply to: orbjeff
Hello Jeff Johnson,
Thanks for replying, the solution that you provided was indeed helpfull and it solved the problem. I was stuck in this for some time and it really helped.
Thanks again for providing a superb solution.
Cheers,
Amit
