I'm using Vault Pro 2013 and I'm creating a DLL with custom commands and that's working fine. Now I want to also add event handlers. Can I do that in the same DLL or do I have to create a separate DLL? If the same DLL, what would the "vcet.config" file have to look like?
I tried adding event handlers to my DLL, but the "OnLoad" function never gets called.
Tom
Solved by orbjeff. Go to Solution.
Tom,
Have you tried adding your event handler to OnStartUp(IApplication application)?
Yes, you can do custom commands and event handlers in a single DLL. Have a look at this article. It should answer your questions about how to set things up, such as the .vcet.config file.
