We use hot runner system and set target pressure after that we choose "runner balance" in Analysis sequence tab. The runner balance analysis is trying to achieve the target pressure by changing the diameters of the runners. How can we know these diameters of the runners?
Solved by mppkumar. Go to Solution.
HI,
After runner balance analysis is complete, the softeare will create a study file with final runner sizes. Just as in best gate analysis.
Hope this is what you asked for!!
Ashwin
Dear Ashwin,
Thank you very much for your reply.
I've read the study file, but I've not seen the final sizes of runner.
Could you please show me more clearly?
Hello @madhukeshwart sir,
is runner analysis is taking lot of time?
Runner size should be same or Variation is allowed, because parts are having different volume.
Thanks.
Hi @Anonymous
based on the constraint, analysis may take more or less time
Runner balancing is done to achieve below mentioned criteria
if the volume of part is different, then the runner sizes should be different to fill both cavities at the same time
refer the below link for more details on runner balancing
http://help.autodesk.com/view/MFIA/2017/ENU/?guid=GUID-6991380A-196B-4179-BFAC-1C1177C5B661
