Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Surface Knitting and Setting Contact Type
1 REPLY 1
375 Views, 1 Reply
I've been having issues when I try to use the Contact -> Create Contact Between Parts feature.  When my models are imported, surface knitting is turn on, and I can see/select the knitted surfaces that were generated between two parts, which to me indicates that Autodesk is seeing the two parts in contact.  However, when I use the aforementioned feature, it is only recognizing one contact pair of which there should be two in this case.
Any ideas on how I can solve this?
Thanks in advance for any and all help.
1 REPLY 1
John_Holtz
Hi nav,
I do not fully understand your geometry. How many parts are there? Which contact pair was created (such as Part A to Part B), and which contact pair was not created (such as Part A to Part C)?
The work around is to select the two surfaces where you want contact, right-click, and choose Contact > whatever.
You can also read "Help > Autodesk Simulation > Mesh Models > Mesh Overview > Contact Pairs" for the various details related to creating contact pairs.
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
