Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Inventor import failure
2 REPLIES 2
576 Views, 2 Replies
I have this part in Inventor and it looks fine, however when I open it in Algor it looks like this.
Why is it doing this and what can I do to fix this?
2 REPLIES 2
I created a simple loft in Inventor to see if I could import it OK. The result was this, even when I selected the "knit surface" command.
John_Holtz
Hi Jason,
In your first post, you only attached the Inventor image. I did not see the Algor image. But in your second post, I can see that too few tesselation surfaces are used to portray the geometry. You can use the "View > Options > CAD Rendering" command to improve the appearance.
We render the CAD surfaces by essentially creating a "mesh", but not an FEA mesh. It is a bunch of shapes (triangles?) on the surface that approximate the mathematical geometry. One way to think of the tesselation size is to imagine a hole. If shown with only 4 sides, it does not look round. As more and more tesselation surfaces are added, it begins to look like a circle. (Is that number 12? 20? 100?)
In some cases, the appearance does not matter; the important question is whether it meshes or not. I have seen situations in which the surface looks kinked or has extra things sticking out, but the model meshes okay. In the case of you second post, the image appears to be complete from what I can see.
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
