Showcase Forum
Welcome to Autodesk’s Showcase Forums. Share your knowledge, ask questions, and explore popular Showcase topics.
psd publish not active in raytracing mode?
2 REPLIES 2
cikho
713 Views, 2 Replies
it disappears..
it is usefull beacuse it exports everything in separated layers (models, background and shadow)..
in raytrace you can use tiff, but certain transparency maps lose the transparency information 😐
_________________________________________________________
almost a showcase PRO user 😛
if you find my post useful, please give kudos or mark as solution 😄
2 REPLIES 2
MarionLandry
in reply to: cikho
HI,
🙂 the menu has not dissapear, it's a matter of how you are accessing it..
When you go to Ray tracing mode and clik "Save" from the raytracing menu, it is true to say that you don't have the PSD option.
It was actually never there before either...
But, if you plublish and image, from the UI menu, then you have access to all file format including PSD files..
Hope this helps
Marion
cikho
in reply to: MarionLandry
oh so in the 2015 is there in the raytracing publish also?
in 2013 sp4 it's not there 😐
good to know that it's there in the latter release 🙂
will try convince my office to update :3
