Spreadsheet calculator 2013 unprotect sheet message
2 REPLIES 2
498 Views, 2 Replies
Dear sir,
Some modules in the spreadsheet when opening gives the message as shown.
When i press enter I can enter to the sheet but some strange things may appear.
for example:
In the "Console Courte " module (French) , The input values when changed did not affect the output result in the module: results still unchanged.
I wonder if I miss something or there is a solution for the password and this module.
Thank you in advance.
Wassim
2 REPLIES 2
Artur.Kosakowski
The warning should not cause any issue and can be ignored by pressing the Cancel button.
Could you make some test for me please?
1. After ignoring the warning (see above) type new set of forces
2. Check if results changed
3. If not change the short cantilever type from a uniform height to a variable height
4. Change it back
5. Have the ratio changed comparing to the original one from the point 2?
Artur Kosakowski
in reply to: Artur.Kosakowski
Dear Sir,
1-When changing the moment & shear values nothing change in ratio.
2-Modifying the Type of cantilever, the ratio change to another value.
3-Restoring the original type of the cantilever (uniform height) it keep the value found in step 2.
4-Changing Values of shear & moment nothing change, i need to repeat step 2 to obtain new value of the ratio
i use Win7 X64, office 2007 32 bits , RSA2013 X64 with last update.
Thank you Artur for your help.
Wassim
