Slice Shell element
6 REPLIES 6
494 Views, 6 Replies
Slice Shell element
Can I slice a curved shell on a particular plane?
6 REPLIES 6
Artur.Kosakowski
I'm sorry I'm not sure if I understand you correctly. Could you make some sketch that illustrate what you would like to achieve please?
Artur Kosakowski
in reply to: Artur.Kosakowski
Artur,
I'd like to slice the curved wall along the plane of the red line.
Tony
Artur.Kosakowski
Seems it is not my best day Smiley Happy
Do you want to divide the panel into two parts (create two panels instead of one) along this line or just see the results along this line?
Artur Kosakowski
No,  I just want to modify the panel geometry to cut off anything above that line
Artur.Kosakowski
See the attached picture. The direction indicates which part to cut off (depends if you indicate top left or bottom right corner of the panel).
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
gun
thanks
