Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Slab supported by Beams
13 REPLIES 13
Message 1 of 14
3418 Views, 13 Replies
Hello.
I'm trying to make something really similar to this: http://forums.autodesk.com/t5/Robot-Structural-Analysis/Meshed-slab-supported-by-beams/td-p/3167096
But I can't support the panel by the beams. When I apply the support, it becomes also in the slab.
Thank you very much.
In attach I have upload an image.
Tags (3)
13 REPLIES 13
Message 3 of 14
Thank you for your answer. But as I said, my problem is similiar to the one I posted.
I just want the same behaviour: http://forums.autodesk.com/t5/Robot-Structural-Analysis/Meshed-slab-supported-by-beams/td-p/3167096, but I can't support my slab in that way (by the beams and not by the default pinned support).
Thank you
Message 4 of 14
Rafal.Gaweda
Send me model and sketch what you want to obtain
Rafal Gaweda
Message 5 of 14
Hello Rafa,
If you read my first post, I've attached a image. As it can be seen, the slab is supported by the 4 pinned supports and not by the two continuous beams. If it was supported by them, the map result will be constant with higher displacement at the mid line between the beams (one direction load distribution).
Hope you'll understand my problem,
Message 6 of 14
Rafal.Gaweda
Your file please.
Rafal Gaweda
Message 7 of 14
Here it is. I also would like to know why my FZ (shear force diagram for bars) isn't linear.
Thank you
Message 8 of 14
Rafal.Gaweda
If you have instabilities you have to correct model first
Error - h can not be 0:
I hope your material is correct
Rafal Gaweda
Message 9 of 14
in reply to: Rafal.Gaweda
My h is 0.001. My panel is a steel grid, so it works only in one direction. I've checked only one panel supported along the edges and the results were ok, so I guess the way I've defined it is pretty close to the reality.
Regarding to the instabilities I'm getting, I have no idea. If I constrained/pinned the nodes where instability is reported, the model will not be the one it should.
Do you have any idea what can I do?
Message 10 of 14
Rafal.Gaweda
Maybe I was not clear enough -> set h at least 0,01 cm to get rid of instabilities
Rafal Gaweda
Message 11 of 14
OK, done! Thank you.
Related to FZ diagram distribution and support conditions of the panels, do you have any idea?
Message 12 of 14
Rafal.Gaweda
I do not understand.
PLease explain.
Rafal Gaweda
Message 13 of 14
In attach: FZ diagram is discretized according to the mesh. I would like to have it linear.
Message 14 of 14
Rafal.Gaweda
Refine MEsh
Rafal Gaweda
