Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Shell Combination Help
9 REPLIES 9
Message 1 of 10
713 Views, 9 Replies
Good Day.
I need to analyze the discharge cone of a steel silo with the following geometry:
I modelled it in Robot by using truncated cones and the result was the following model:
I still have a problem though, as I do not know how to combine the cones to obtain a hollow surface. I know there is an option in Robot to combine objects but I do not know how to use it in this case. Could anyone help me with it?
Thank you for your assistance.
9 REPLIES 9
Message 2 of 10
Artur.Kosakowski
You need to create these object as ACIS ones first.
Artur Kosakowski
Message 3 of 10
in reply to: Artur.Kosakowski
Thank you for your assitance, could you please explain how did you do this?
Thanks again.
Message 4 of 10
Artur.Kosakowski
View inclined cone silo with acis objects
Artur Kosakowski
Message 5 of 10
Thank you for your detailed explanation.
Message 6 of 10
Hello again.
I'm trying to model the cone following the video, but the following message keeps appearing:
"Execution error no. 19027 of the ASM geometrical kernel"
After I cut off the cone, I attempt to mirror it and the panel just disappears. Why is this happening and how do I solve it?
Message 7 of 10
Artur.Kosakowski
This library is not native Robot functionality which makes giving you the answer a bit challenging. I'd start with asking you to restart the program and try again.
Could you check if the file you attached is the right one as I after opening it I can see the whole silo rather than the part from the picture you inserted please?
Artur Kosakowski
Message 8 of 10
Hello again. I've alredy tried to restart the program, and I even restarted the computer and the error keeps popping out.
On the other hand, yes I attatched the model of the whole silo, as recently I was required to check the entire structure. So, I attempted to follow the instructions on the video on my file and the error started to appear.
Message 9 of 10
Artur.Kosakowski
The whole silo with standard panels.
Artur Kosakowski
Message 10 of 10
Hi I have shell model with rectangular openings, and I'm trying to filled the corner using Filled 3d Tool, but when I'm doing I received ASM error similar to what we discussed in the tread.
Tags (1)
