Message 1 of 38
HoshangMustafa
1557 Views, 37 Replies
Ribbed slab
Hi
Artur wrote:
 My approach is to model a rectangular beam ('web') with no offset but with artificially increased moment of inertia (see theattached picture - IY of rectangular beam multiplied by ratio of IY of  T shape beam / IY of rectangular beam). This approach causes'increaseof bending in the beam (T shape beam effectwhile no axial forcse in the beam being generated.
Plz find the attached file. I applied this approach, but ARSA gave warnings & errors. Plz any guide.
37 REPLIES 37
Message 2 of 38
Hi
I sent my file using WeTransfer. I made design for ribbed slab, girders, columns. I appreciate your notifications.
Message 3 of 38
in reply to: HoshangMustafa
Hi Mustafa
I think the error message is caused by
1.-  the dimensions of your beams are defined as 0.3x0.65 millimeters
2.- you don't have make any load combination in order to design in ULS or SLS
Marcelo
Message 4 of 38
HoshangMustafa
Hi Artur
I posted the rtd file via WeTransfer & YouSendIt to this email adress:
mailer@lithium.com.
Plz notify me if this is delivered and notify me for any suggestions.
Message 5 of 38
No,
using any of these services you have to send it to yourself (your e-mail address) and then copy and paste to post only the link to file you got from the service.
Rafal Gaweda
Message 6 of 38
Hi
Plz see the lonk below:
https://www.wetransfer.com/downloads/450cfebde2834d3bf1932398f47cfaa520130403073248/876e0cf209754277...
It's the modelling of ribbed slabs based on  approach of Artur. Is it O.K?
Why are all columns give the same reinforcement or I'm wrong?
Message 7 of 38
See below
Rafal Gaweda
Message 8 of 38
Hi
Thanx Rafal
So is the cross section of the columns is adequate.
Another question:
When I export the drawings of beams to dxf, instead of displaying diameter it desplays (Latini:D8).
How can I solve this?
Message 9 of 38
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Problem-importing-to-Autocad-fonts/td-p/3819...
Rafal Gaweda
Message 10 of 38
Hi
I downloaded AutocadAdditionalFonts but it doesn't help
Message 11 of 38
Open dxf file in Notepad, replace ALL
{LATIN1:D8}
by
 %%c
Save file, load to acad
Rafal Gaweda
Message 12 of 38
Hi Rafal
Thanx. This is working, but why AutocadAdditionalFonts doesn't work?
Message 13 of 38
It was for ASD fi font. I thought it was the same font in Robot.
Rafal Gaweda
Message 14 of 38
Hi
Can you modify it to be accomodated for ARSA?
Message 15 of 38
Hi In Arsa 2009 The diameter was represented as #. There was no problems in exporting it to Dxf.
Message 16 of 38
I hope it will be corrected soon.
Rafal Gaweda
Message 17 of 38
Hi
I hope too. Till now I don't know how to export a panel design to dxf with the panel thickness shown and the reinforcement also shown on cross section of panel.
another problem. In beams definition I labelled my beams with B-1, B-2 etc. In the design drawing the table title will be Beam221, Beam222 instead of B-1, B-2.
How this is solved?
Message 18 of 38
Hi
I tried to change the name syntax, but it doesn't help.
Message 19 of 38
Not possible.
You can create such view in ASD
I do not get. This is what I see:
Rafal Gaweda
Message 20 of 38
Hi
Not possible.
How can I use ASD? I'm not familiar with that.
