Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
[Revit-Robot] How to clean in Revit all Robot data
39 REPLIES 39
Message 1 of 40
1238 Views, 39 Replies
I would like to clean all data in Revit that were imported from Robot: member numbers, advanced bar properties, load combinations, member types, etc. How to do it? This is for troubleshooting.
39 REPLIES 39
Message 2 of 40
Artur.Kosakowski
The only option I can think of is to use Revit API and unbind the items from the attached picture (Manage > Shared Parameters in Revit) from Revit categories.
Artur Kosakowski
Message 3 of 40
Or perhaps remove these parameters in this window? Would it give the same effect as unbinding via API?
Message 4 of 40
Artur.Kosakowski
No, not all Robot 'data' will be removed in this way.
Artur Kosakowski
Message 5 of 40
in reply to: Artur.Kosakowski
I suppose that you heve to delete the "R2R...." shared parameters/
Message 6 of 40
I've erased RM_R2R_LinkSessionIdList, RM_R2R_OriginOffset and RM_RSLoads. Now When I export to Robot I get an Error/Warning saying: "Parameter RM_R2R_OrginOffset, RM_R2R_LinkSessionIdList, RM_RSLoads not defined in shared parameters file "C:\Program Files\...\RMParam.txt".
It doesn't cause any problems, but I'm still curious why this appears.
Message 7 of 40
Artur.Kosakowski
The reason I wrote unbind (and did not write remove) was that you should not remove (you should unbind). This might have corrupted the link and is not what should be done.
Artur Kosakowski
Message 8 of 40
How do you "unbind" a share parameter?
Message 9 of 40
I would also welcome some explanation and perhaps sample code. There are no examples for unbinding parameters this in the Revit API documentation.
Message 10 of 40
Rafal.Gaweda
I will post macro doing that when it is ready.
Rafal Gaweda
Message 11 of 40
Rafal.Gaweda
in reply to: Rafal.Gaweda
Ready for RST 2013.
It clears all Revit Extensions parameters together with RST-Robot link parameters.
Copy attached files with folder from zip to
[c:\ProgramData\Autodesk\Revit\Addins\2013]
So it should be :
c:\ProgramData\Autodesk\Revit\Addins\2013\DREXProjectCleaner\DREXProjectCleaner.dll
c:\ProgramData\Autodesk\Revit\Addins\2013\\DREXProjectCleaner.addin
Then this module will be available in Add-Ins tab as shown below:
To run it just press OK on next window
Rafal Gaweda
Message 12 of 40
Rafal.Gaweda
For 2012
[c:\ProgramData\Autodesk\Revit\Addins\2012]
So it should be :
c:\ProgramData\Autodesk\Revit\Addins\2012\DREXProjectCleaner\DREXProjectCleaner.dll
c:\ProgramData\Autodesk\Revit\Addins\2012\\DREXProjectCleaner.addin
Rafal Gaweda
Message 13 of 40
Can I do something about that?
Message 14 of 40
Rafal.Gaweda
I've erased ....
Have you done it manually or by this addin?
Rafal Gaweda
Message 15 of 40
Could you consider publishing the source code for this script? I am sure the advanced users would appreciate it.
Message 16 of 40
Rafal.Gaweda
No, sorry.
These Addins are developed by ADSK, copyrighted etc.
Rafal Gaweda
Message 17 of 40
@Anonymous_Adsk wrote:
I've erased ....
By hand
Message 18 of 40
Rafal.Gaweda
Use clear then chek.
Rafal Gaweda
Message 19 of 40
I will appreciate a new 2014 version of this plugin.
Message 20 of 40
I am trying to run this on 2013 now and I think it is installed correctly, because it shows up in the External Tools menu. But when I click to run it, it does not seem to be doing anything, there is no message no nothing. And Robot data are still there.
