quasi-permanent combinations
9 REPLIES 9
Message 1 of 10
2035 Views, 9 Replies
When I try to calculate provided reinforcement for my beam I get the following error: "There are no quasi-permanent combinations. calculations may be incorect".
9 REPLIES 9
Message 2 of 10
Artur.Kosakowski
Is it the same issue that has been solved here http://forums.autodesk.com/t5/Autodesk-Robot-Structural/SLS-combination/m-p/3316923/highlight/true#M... ?
Just try to select SLS:QPR instead of SLS while defining combinations.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 10
in reply to: Artur.Kosakowski
I have selected SLS:QPR
Message 4 of 10
Artur.Kosakowski
Please send me the rtd file and indicate which beam you want to design as well as which load cases you wanted to use for the design.
Artur Kosakowski
Message 5 of 10
I can't send the file, because I can't get the file size small enough, even though i compress it with winRAR. Is there any other way I can send it to you?
Message 6 of 10
Artur.Kosakowski
Before we try anything else:
1. Open your file
2. Delete all other elements from the model but the beam you want to import (do not edit/delete loads or combinations)
3. Make sure it is supported (add some nodal supports or column if needed)
4. Calculate model
5. Check if you have the same problem with combination type
6. Save the model under a new name and send it (should be small enough)
Artur Kosakowski
Message 7 of 10
 I want to design the indicated T-beam. Using the Uls combination and SLS:QPR combination
Message 8 of 10
Artur.Kosakowski
I can't see any problem with doing so. There is no message displayed. Could you make either sequence of screen captures or a small move to show your steps and what happens on your computer please?
Artur Kosakowski
Message 9 of 10
Message 10 of 10
Artur.Kosakowski
The difference is that I'm using v.2012 with SP4 installed whereas you have no SP installed. The SP4 should be available for download at the of this week from http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
In addition I think you should correct the nestled definitions of combinations
Artur Kosakowski
