Mode direction X and Y
13 REPLIES 13
Message 1 of 14
785 Views, 13 Replies
Hi all.
I want find Mode direction X and Y.????
13 REPLIES 13
Message 2 of 14
Rafal.Gaweda
Look at mode shape diagrams display.
Rafal Gaweda
Message 3 of 14
My model seems to display a different mode shape than it should be
as my colleagues told me the mode shape is supposed to be this way:
mode 1 drift to x
mode 2 drift to y
mode 3 twising
I attach my model please take a look and help me on this
Message 4 of 14
Romanich
Can you upload the model? I can't see mesh on floor slabs.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 5 of 14
in reply to: Romanich
Unfortunately I cant Upload my File
😞 its 74 mb in size
regarding the mesh on floor slabs, i set it to rigid diaphram and it never meshed
please see photo
Message 6 of 14
by the way, the model i am using is the seismic model from robot
Message 7 of 14
Rafal.Gaweda
Message 8 of 14
Romanich
By default in this model for the floor slabs is assigned the calculation model Curtain Wall.
Roman Zhelezniak
Message 9 of 14
Romanich
Create new one with the same options and select Stiffening diaphragm instead of Without stiffening.
Roman Zhelezniak
Message 10 of 14
in reply to: Rafal.Gaweda
hi Rafal,
I cant seem to open the links on what you posted. maybe our it prohibited it.
anyway, can i send it on your email instead?? if its possible
about curtain wall setting on the floor slab, I already changed it to rigid diaphram with FEM meshing.
still it not genereting the mode that is desirable
See attached three modes
My Colleaugues told me that member stiffening maybe the cause of mode 1 to be twisting, but I doubt that because my model is prismatic and corewalls are placed on the same place as the other, much like a mirror image.
Can you please help me on how to do this right?
From My understanding, this is the forst step to do before going to an in depth seismic analysis as I need the natural period of the building
Message 11 of 14
Romanich
If you have torsion in the first mode, you should to change a floor layout. For example to add walls on the perimeter.
Roman Zhelezniak
Message 12 of 14
Done that Sir and It helped. ^_^ Thanks!Cat Happy
Message 13 of 14
Mirko.Jurcevic
Of course you will have torsion in the first mode (which is bad) beacause you have two cores in the middle of the structure floor so close to each other.
As mr. Romanich said, adding shear walls to perimeter of the structure should solve the problem.
I am attaching two images, maybe they can help.
Also, take a look at this link.
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Message 14 of 14
in reply to: Mirko.Jurcevic
Thanks! this is a great help!Smiley Happy
Tags (2)
