Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Minimum eccentricity for steel simple columns
2 REPLIES 2
2431 Views, 2 Replies
How would we model minimum exccentricity for a simple beam-column connection.  i.e. 100mm+d/2 to indue some bending into the column following the collection of a simple beam?
Most structural programs that I have used, will have an option to include this during analysis; however, the robot structural module simply calculates the column in pure axial with no bending.
Any ideas?
Many Thanks
Andy
2 REPLIES 2
Artur.Kosakowski
Use the reduce length offset on the beam. The value of the offset (bending moment) will automatically follow the change in the column size.
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-63486561-1D79-4056-A945-890FD7CED7AB.htm
Artur Kosakowski
in reply to: Artur.Kosakowski
Many thanks for your response. I will give it a try later on today. Regards, Andrew Simpson
