loads following deformation shape
5 REPLIES 5
331 Views, 5 Replies
¿how to perform a load which follows the deformed shape of the structure?
I mean, for example an horizontal load. Instead of being always perfectly parallel to X axis, to be perpendicular to the bar.FOLLOWER LOAD.PNG
5 REPLIES 5
Artur.Kosakowski
There is no such option in the current version of Robot.
Artur Kosakowski
in reply to: Artur.Kosakowski
Understood.
On the other hand, could you please explain me in the bar nº 4 of the attached file there is no deformation? I did all the combinations to understand.
Alos, what for is absolute/relative?
Artur.Kosakowski
I have to admit that asking me to find the answer based on a picture rather than a model is sometimes challenging Smiley Wink
Is the local Z perpendicular to the screen? If yes, set the projection to the isometric view.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Sorry
I forgot to attach the file.
Artur.Kosakowski
The use of local and projected together hasn't got any physical sense since there in such definition of the load there is no definition of the plane on which to project the load . In short such load is not applied. What is more it cannot be defined in the corresponding load definition dialog.
The relative vs. absolute are for a situation when you want to define load on a part of a bar only.
Artur Kosakowski
