Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Load to mass problem
2 REPLIES 2
372 Views, 2 Replies
When I try to convert load to mass, the program converts the loads that are applied on bars only, not those on shell elements.
2 REPLIES 2
Artur.Kosakowski
Create a new load case where you have only loads applied to shells. Run static analysis of this case and check that the load is applied correctly. Then in the modal analysis mark disregard density and convert only the new load case to mass. Run calculations and check the total mass in the results of modal analysis case. If it is 0 then send us this model.
Artur Kosakowski
in reply to: Artur.Kosakowski
Thank you Artur!
