Difficulty creating mesh
1 REPLY 1
234 Views, 1 Reply
Good morning,
other modeling issues of mesh.
If you create the mesh on the attached file:
- Good connection between the vertical cylinders
- Lack of connection with the plates of the rings
- Lack of connection with the cylinder tilted
If join all cylinders (vertical and inclined) by UNION:
- Good connection between the elements of the cylinders
- Change of position between the flat elements that discretize the vertical cylinder
How can I create a good mesh for items modeled?
Daniel
1 REPLY 1
Artur.Kosakowski
Please use the suggestions from the two webinars for meshing plus the ones you should get from me via the reseller for your support case.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
