Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Difference between Rabar database selected in preferences and design output.
5 REPLIES 5
m_zaman
348 Views, 5 Replies
Hello.
I have selected PN Metric Rebar, But after design procedure it shows and selects Imperial rebar. I have attached a picture and a file.
Could you please help me?
Thank you.
5 REPLIES 5
Mohammed_Ata
in reply to: m_zaman
You should choose the database on which you want to work .
see attachment.
m_zaman
in reply to: Mohammed_Ata
If you see my picture that attached you will see that i selected Metric database and i want to use only Required reinforcement Module not Provided... module. is there any idea?
thank you
Artur.Kosakowski
Any reason why you want to use Polish rebars with the US code? Perhaps you should use the American version of these two instead? Mind that you should redefine both the member type and calculation parameters.
Artur Kosakowski
m_zaman
in reply to: Artur.Kosakowski
No matter what i choose. it always shows Rebar results in imperial format.
I have attached a new picture and file.
could you please help me?
thank you.
Artur.Kosakowski
The file with reassigned code parameters.
Artur Kosakowski
