Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Claddings creating unstability type 2
3 REPLIES 3
281 Views, 3 Replies
I created a model of beams and columns with some pinned and fixed connections.
I first defined loads on these beams and columns and everythings works fine.
Then I defined claddings to apply planar loads and an unstability type 2 appears one noad (always the same).
If I suppress the cladding next to these node, everything works again.
More surprising, if I keep this problematic cladding but create a new load case, the unstabilty happens to disappear, but reappear when I create a second new one.
I checked and the four nodes defining the cladding really looks in the same plan.
Do you have any idea how to solve this ?
Charles TACHOT,
ECM
3 REPLIES 3
Artur.Kosakowski
Is it the same when you set the solver to Skyline?
Artur Kosakowski
in reply to: Artur.Kosakowski
With solver skyline the unstability turns to type 1.
By the way, I forgot to say that, despite the unstability results look quite good.
Charles
Artur.Kosakowski
Try to define a unit force or moment in the reported location for the reported d.o.f and check values of max. displacements and rotations. I don't think that you can ignore the instability of type 1 reported by the Skyline solver.
Artur Kosakowski
