Autodesk certification expired
6 REPLIES 6
gustavo_c_vasconcellos
707 Views, 6 Replies
Dear support,
I tried to generate a printout composition in a World documentation and I received a message (inside word) that Autodesk certification is expired.
See attached picture, what should I do? How can I validate the signature.
I am running Robot 2012 and Word 2007 (Brazilian Edition), on Windows 7 Professional.
Gustavo
6 REPLIES 6
This macro has never been signed.
We will check what we can do. For now ignore this warning.
Rafal Gaweda
Dear Rafal,
but the print out is not exported to Word even if I ignore the message.
Gustavo
Have you enabled macros in Word?
Rafal Gaweda
Hi Rafal,
all the macros are enabled (see attached), in addition of this, I installed openoffice and recieved another error message (see attached).
Gustavo
Try this
open Command Prompt as ADMIN
then
 unregister ALL ROBOTS you have installed on your computer by command: path_to_robot.exe / unregserver
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2011\System\Exe\robot.EXE" /unRegServer
(use such line as above in this Comand Prompt window)
then
register the one you want to use.
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\System\Exe\robot.EXE" /RegServer
then check
Rafal Gaweda
Great, it is working now!!!
Gustavo
