Hi all,
I was trying to adapt some macros that some users gently post here on Discussion Groups.
I already made a part of what i wanted...but this is the first time i'm trying to use macros, so i'm not being able to do the rest.
I have already a way to have all forces on my xls file, but i want to get in the following columns Lenght(m) | Section | Rect_BF | Rect_HT | Rect_EP | Bar Name | Deflection (mm)
How can i do this? Can you help me?
Thanks, please see attachement
Solved by Rafal.Gaweda. Go to Solution.
Example code:
The sectional data \ interface \ access depends of section type: from database or user or tappered or complex ....
What sections do you have?
Dim RobApp As New RobotApplication Dim Bar As IRobotBar Dim Sel As IRobotSelection Dim Sec As RobotBarSection Dim BarCol As RobotBarCollection Dim sectData As IRobotBarSectionData Set Sel = RobApp.Project.Structure.Selections.Get(I_OT_BAR) Set BarCol = RobApp.Project.Structure.Bars.GetMany(Sel) For i = 1 To BarCol.Count Set Bar = BarCol.Get(i) Set sectLab = Bar.GetLabel(I_LT_BAR_SECTION) Set sectData = sectLab.Data Set Sec = Bar.GetLabel(I_LT_BAR_SECTION) Cells((7 + i), 1) = Bar.Number Cells((7 + i), 2) = Bar.Length Cells((7 + i), 3) = Sec.Name Cells((7 + i), 4) = sectData.GetValue(I_BSDV_AX) ' A of section Cells((7 + i), 5) = sectData.GetValue(I_BSDV_D) ' h of section Next i Exit Sub
I have regular Rc Beams and Rc Columns.
I tried to copy that code to "my" macros but it simply not work...where should i paste that?
Thanks in advance
OK , I will show you.
It was example for steel sections - copy it to separate xls file
Thanks Rafal, if you don't mind please check the attachement on my first post.
Hi Rafal,
I'm seeing that this macro is for 2 or more points in a bar.
What should i do to extract data only for 1 point?
For example:
I want data (forces, section propreties, etc...) for the point x=0 of the bar.
Thanks in advance,
Cheers!
Small modifications and we have a new macro ... attached
Hi again,
Other question?
The current output is organized by nodes, i.e:
Barra | Nó | Caso |
1 | 53 | 17 |
1 | 54 | 17 |
1 | 53 | 18 |
1 | 54 | 18 |
1 | 53 | 19 |
1 | 54 | 19 |
1 | 53 | 20 |
1 | 54 | 20 |
What should i do to have this output:
Barra | Nó | Caso |
1 | 53 | 17 |
1 | 53 | 18 |
1 | 53 | 19 |
1 | 53 | 20 |
1 | 54 | 17 |
1 | 54 | 18 |
1 | 54 | 19 |
1 | 54 | 20 |
Thanks!
@Anonymous_GOOD wrote:
hi.
File excel erro ???????
Macros from this thread do not work with selections made in robot.
Fill correct data in Excel cells or modify macro.
Barra Nó Caso 1 53 17 1 54 17
Barra Nó Caso 1 53 17 1 53 18
Just one loop should be changed ... file in message 19, below
Hi Rafal, i tested this last file you sent to user FilRib and something is not ok....because that macro puts forces on end node equal to origin node.
Yep, my mistake.
I think that the successive adaption turned the process too messy.
I tried this one and i found that for origin nodes some values are not ok (example: My and Mz), on the other hand if you have more then one combination, forces for end node still remains equal to origin node.
Or am i seeing this wrong?
No, you are right. To many modifications.
Check this one.
