about loads combining
6 REPLIES 6
475 Views, 6 Replies
Hello everybody……
I tried to find a solution for my question in the topics, but I didn’t find anything.
My question is about combining the loads. I have several groups of loads:
Dead – G1 (1);
Live – Q1 (2);
         - Q2 (3);
Wind – W1 (4);
           - W2 (5);
Snow – S1 (6);
I prefer to use automatic code combinations. So how to tell the program do not aloud simultaneous acting in generated code combinations of these loads: (3) with (4), (3) with (5), (4) with (5), and (3) with (6).
I will be very grateful if someone explains the method step by step.
Thank you very much.
6 REPLIES 6
Rafal.Gaweda
Create new subnatures of LIVE loads for wind and snow, define these W and S cases using them, set correct relations for automatic code combination generation
Rafal Gaweda
in reply to: Rafal.Gaweda
Thank you for your answer.
I tried to do this by myself, but unfortunately I couldn't understand the logics of the operations of the program. So please, can you explain the process in details.
Thank you again......
....If I change the NATURE of the wind and snow loads - in generated cobinatins they will get wrong coefficient ψ depending on their nature.....
Rafal.Gaweda
There are always some pros and cons in case of doing nonstandard operations
Rafal Gaweda
I'm sorry, but this is stupid.......This option is a basic requirement for using the software......
Rafal.Gaweda
In Robot you can not deal with relations between cases in different natures.
Rafal Gaweda
