Show only
Search instead for
Been using Revit for about 3 years and i still haven't figured out the best way to do sloped steel roofs. Should i be placing my structure on a sloped reference plane? Or does it make more sense to just modify the end points? Thanks for the help.
Personally, I like to use a reference plane to get the geometry initially placed correctly. From there I will ensure that the end points are relative to the same level, if possible.
