Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rebar Tags and Parameters
2 REPLIES 2
stewartg
876 Views, 2 Replies
Hi All
I'm doing my first RC drawing in Revit, but the Rebar Tags do not display how I would like them.
In the Project each Rebar Element has a property called "Rebar Comments", in which I have put a description. I think it is a Project Parameter.
I have already done some changes to the Rebar Tag Family but this parameter is not available.
How can I transfer this property from my Project into the family? I have tried "Transfer Project Standards" but this does not seem to work.
Thanks in advance
2 REPLIES 2
jachyme
in reply to: stewartg
Hi, unfortunately Project Parameters can't be used in tags. For Rebar there is in-built parameter Comments which is the best choice to add any comment to rebar instance and it is visible everywhere you use Structural Rebar category.
Ewa Jachym
Principal User Experience Designer
stewartg
in reply to: jachyme
Of course - Why didn't I work that out for myself.
I'm using the Comments parameter as a beam numbering sytem at the moment, but there is no reason why I can't swap them arouind
Thanks jachyme
Forma Design Contest
