I am working with Revit Sofistik 2023 and I want to divide the load I have given to the whole building to individual rooms. I referred some videos which suggested me to use the modelline option then use the SOF_LoadDIV model line. But I cannot find it in the modelline option. Can anyone help me with this? Is there someother way to do it?
Thank you!!
Solved by jay_colcombe. Go to Solution.
From reading the help from Sofistik
Loads > Load Pattern - SOFiSTiK Analysis + Design 2023
Is it simply that you have to create Model Lines to define rooms or Pattern Areas so the sofistik tool can identify such regions?
Help | Place a Model Line | Autodesk
From
I have to see the deformation in sofistik in each room individuallly. So, I have divide the load appplied on the whole building and divide it for each room. I have attached two pictures below to show the difference:
My understanding from the Load Pattern Tool in Sofistik is that you create Revit model Lines to define Area/Divisions (these would be rooms for you). You then run the Load Pattern Tool > Select the Area Load to be Divided and then Click on the Model Lines to Define the Areas/Rooms/boundary and this adds a new Parameter called SOF_LoadDIV into the model called which is an automatically calculated Value of the Whole Area Load divided into these specific areas.
IF i have missed the point maybe it is something you need to discuss with Sofistik as it is their addin?
It a shame you could not use Rooms/Spaces/Zones/Areas boundary automatically as this would make life a lot easier.
