Hi Forum,
I would like to ask for help. I think I kinda know my way around rebar in revit, but recently I came across this really basic need for reinforcement and it surprised me how difficult this is for me.
I want to create put rebar like red line in following picture in wall consisting of 3 parts (divided by green lines). I can do 3 separate parts of rebar (straight - bend - straight), but thats not good. Can someone help me please?
PS: Freeform rebar didnt work.
Dan.
Solved by EdwinG. Go to Solution.
Thanks for quick response. I have a question, ability to control extension (length) is only by constrains in the cas of use freeform rebar?
Indeed, editing the bar constraints is the way to adjust the bar geometry.
You can also trim or extend the bars to other structural elements, including additional geometry, in case shortening all bars by the same offset doesn't produce the expected results.
