Do you know any add-in that will convert Drafting View to Legend?
Albert
Solved by Lucavox. Go to Solution.
Hello Albert, I think you have two ways to do this.
- Export a dwg of the drafting view and import it in a legend
- Copy the lines in the drafting view and paste them in the legend (you may draw directly in the legend)
I hope is useful.
Luca
Thank you for the response, I appriciate that
What I am thinking a way to not to go to that way, an add-in that will make a drafting view into legend in one command because if I will gonna do what you suggested, I will gonna have to spend lot of time for that because we are talking about hundreds drafting views
albert
I think It's not so simple but you could create a macro/addin with the function below and perform a copy between views.
ElementTransformUtils.CopyElements(View, ICollection<ElementId>, View, Transform);
this post may help you to create an addin:
http://adndevblog.typepad.com/aec/2013/05/copy-family-between-documents-via-api.html
I hope it is helpful.
Looking forward to hear from you,
Regards
Luca
