Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Beams stop short of T shaped column, how to fix?
2 REPLIES 2
stgauss
926 Views, 2 Replies
Anybody know why the beams on this T shaped column are doing the following?
They seem to be joined, yet they stop short of the central area of the column, where they should end. Unjoining them, or using the extend/trim command doesn't seem to have any effect. It seems that Revit is taking the external face as the end point for the beam, instead of the internal one.
It occurs to me that if I take the beam from side to side (instead of using 2 separate beams) and force it to intersect the column, it should take care of the problem. But, that solution aside, is there some parameter that can be altered in this case to make the beams join where they're supposed to?
2 REPLIES 2
dkwolek
in reply to: stgauss
Setback is always calculated from the bounding box of the element into which the shortened element is joined.
For 2015 Revit release new functionality was introduced to handle such cases.
The command is available on the contextual tab for structural framing elements.
When a structural framing element is selected, then two new buttons are visible.
Change Reference changes the reference face for Setback.
For more details please refer to below movie.
http://akn.autodesk.com/maps/ENU/873176874#n=8178997221&c=172234315
Hope that helps
Dariusz Kwolek
Structural Product Manager
AEC Solutions
Just follow my attached files. You will get your resolution. Just edit the column family and after that what will you do please see the attached image file.
Thanks & regards,
Subhradeep Sen
kolkata
India
