Comunidade
Revit & Navisworks & Construction Cloud - Português.
Compartilhe seu conhecimento, faça perguntas colabore com ideias e explore os tópicos mais populares de Revit & Navisworks.
cancelar
Mostrando resultados para
Mostrar  apenas  | Pesquisar então
Você quer dizer:
Erro instalação Revit 2015 em Windows 8.1
48 RESPOSTAS 48
SOLUCIONADO
Responder
Mensagem 1 de 49
williamhm
16802 Exibições, 48 Respostas
Ao tentar instalar o Revit 2015 em um PC com Windows 8.1 x64 bits, aparece uma tela de erro, conforme imagem, tem tambem o arquivo de log que segue abaixo.
Se puderem me ajudar agradeço.
Erro Autodesk Revit 2015
2014/4/14:23:09:40 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:09:40 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:09:40 WW--Honorio WW-HONORIO Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm
2014/4/14:23:09:40 WW--Honorio WW-HONORIO Launch
2014/4/14:23:09:40 WW--Honorio WW-HONORIO CommandLine
2014/4/14:23:09:40 WW--Honorio WW-HONORIO Setup Windows update reboot is pending
2014/4/14:23:10:24 WW--Honorio WW-HONORIO Setup Autodesk Revit 2015 Will restart automatically.
2014/4/14:23:10:24 WW--Honorio WW-HONORIO === Setup ended ===
2014/4/14:23:15:53 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:15:53 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:15:53 WW--Honorio WW-HONORIO Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm
2014/4/14:23:15:53 WW--Honorio WW-HONORIO Launch
2014/4/14:23:15:53 WW--Honorio WW-HONORIO CommandLine
2014/4/14:23:15:54 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:15:54 WW--Honorio WW-HONORIO Current Directory C:\Users\WW--HO~1\AppData\Local\Temp\_AI40C8.tmp
2014/4/14:23:16:15 WW--Honorio WW-HONORIO === Setup ended ===
2014/4/14:23:16:08 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:16:08 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:16:08 WW--Honorio WW-HONORIO Current Directory C:\Users\WW--HO~1\AppData\Local\Temp\_AI40C8.tmp
2014/4/14:23:16:08 WW--Honorio WW-HONORIO Launch
2014/4/14:23:16:10 WW--Honorio WW-HONORIO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\WW--HO~1\AppData\Local\Temp\_AI40C8.tmp\Setup\RevitSetup.dll
2014/4/14:23:16:10 WW--Honorio WW-HONORIO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/14:23:16:14 WW--Honorio WW-HONORIO Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\WW--HO~1\AppData\Local\Temp\_AI40C8.tmp\Setup\RevitSetup.dll
2014/4/14:23:16:14 WW--Honorio WW-HONORIO Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2014/4/14:23:16:15 WW--Honorio WW-HONORIO PageOpen LaunchDialog
2014/4/14:23:18:20 WW--Honorio WW-HONORIO PageOpen LicenseDialog
2014/4/14:23:18:23 WW--Honorio WW-HONORIO PageOpen ProductInfoDialog
2014/4/14:23:19:47 WW--Honorio WW-HONORIO PageOpen ProductSelectionDialog2
2014/4/14:23:20:53 WW--Honorio WW-HONORIO PageOpen FullProgressDialog
2014/4/14:23:20:53 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2014/4/14:23:21:11 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2014/4/14:23:21:12 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\WW--HO~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/14:23:21:27 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2014/4/14:23:21:27 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2014/4/14:23:21:44 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2014/4/14:23:21:44 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/14:23:22:23 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/4/14:23:22:24 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/4/14:23:23:03 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/4/14:23:23:03 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:23:23:03 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Failed Installation aborted, Result=2
2014/4/14:23:23:03 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/14:23:23:03 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/4/14:23:23:03 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/14:23:23:07 WW--Honorio WW-HONORIO PageOpen InstallCompleteDialog
2014/4/14:23:23:27 WW--Honorio WW-HONORIO === Setup ended ===
2014/4/14:23:33:44 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:33:44 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:33:44 WW--Honorio WW-HONORIO Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm
2014/4/14:23:33:44 WW--Honorio WW-HONORIO Launch
2014/4/14:23:33:44 WW--Honorio WW-HONORIO CommandLine
2014/4/14:23:33:44 WW--Honorio WW-HONORIO Current Directory C:\Users\WW--HO~1\AppData\Local\Temp\_AI9BBB.tmp
2014/4/14:23:33:47 WW--Honorio WW-HONORIO === Setup ended ===
2014/4/14:23:33:45 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:33:45 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:33:45 WW--Honorio WW-HONORIO Current Directory C:\Users\WW--HO~1\AppData\Local\Temp\_AI9BBB.tmp
2014/4/14:23:33:45 WW--Honorio WW-HONORIO Launch
2014/4/14:23:33:45 WW--Honorio WW-HONORIO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\WW--HO~1\AppData\Local\Temp\_AI9BBB.tmp\Setup\RevitSetup.dll
2014/4/14:23:33:45 WW--Honorio WW-HONORIO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/14:23:33:47 WW--Honorio WW-HONORIO Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\WW--HO~1\AppData\Local\Temp\_AI9BBB.tmp\Setup\RevitSetup.dll
2014/4/14:23:33:47 WW--Honorio WW-HONORIO Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2014/4/14:23:33:47 WW--Honorio WW-HONORIO PageOpen LaunchDialog
2014/4/14:23:33:49 WW--Honorio WW-HONORIO PageOpen LicenseDialog
2014/4/14:23:33:51 WW--Honorio WW-HONORIO PageOpen ProductInfoDialog
2014/4/14:23:35:07 WW--Honorio WW-HONORIO PageOpen ProductSelectionDialog2
2014/4/14:23:36:34 WW--Honorio WW-HONORIO PageOpen FullProgressDialog
2014/4/14:23:36:35 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Failed Installation aborted, Result=2
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/4/14:23:36:37 WW--Honorio WW-HONORIO PageOpen InstallCompleteDialog
2014/4/14:23:39:33 WW--Honorio WW-HONORIO === Setup ended ===
2014/4/14:23:47:20 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:47:20 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:47:20 WW--Honorio WW-HONORIO Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm
2014/4/14:23:47:20 WW--Honorio WW-HONORIO Launch
2014/4/14:23:47:20 WW--Honorio WW-HONORIO CommandLine
2014/4/14:23:47:20 WW--Honorio WW-HONORIO Current Directory C:\Users\WW--HO~1\AppData\Local\Temp\_AIFC8.tmp
2014/4/14:23:47:25 WW--Honorio WW-HONORIO === Setup ended ===
2014/4/14:23:47:21 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:47:21 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:47:21 WW--Honorio WW-HONORIO Current Directory C:\Users\WW--HO~1\AppData\Local\Temp\_AIFC8.tmp
2014/4/14:23:47:21 WW--Honorio WW-HONORIO Launch
2014/4/14:23:47:22 WW--Honorio WW-HONORIO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\WW--HO~1\AppData\Local\Temp\_AIFC8.tmp\Setup\RevitSetup.dll
2014/4/14:23:47:22 WW--Honorio WW-HONORIO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/14:23:47:25 WW--Honorio WW-HONORIO Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\WW--HO~1\AppData\Local\Temp\_AIFC8.tmp\Setup\RevitSetup.dll
2014/4/14:23:47:25 WW--Honorio WW-HONORIO Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2014/4/14:23:47:25 WW--Honorio WW-HONORIO PageOpen LaunchDialog
2014/4/14:23:47:39 WW--Honorio WW-HONORIO PageOpen LicenseDialog
2014/4/14:23:47:40 WW--Honorio WW-HONORIO PageOpen ProductInfoDialog
2014/4/14:23:50:36 WW--Honorio WW-HONORIO PageOpen ProductSelectionDialog2
2014/4/14:23:51:17 WW--Honorio WW-HONORIO PageOpen FullProgressDialog
2014/4/14:23:51:17 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Failed Installation aborted, Result=2
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
Erro Autodesk Revit Content Libraries 2015
48 RESPOSTAS 48
Mensagem 21 de 49
em resposta a: williamhm
Olá.
Meu nome é Lucas e estou com problemas com a instalação do Revit 2015. Meu sistema operacional é Windows 8.1, 64-bit.
Após baixar o setup, é necessário manter a janela de conexão com a conta autodesk aberta, porém, mesmo com ela aberta o erro permanece como mostra na imagem abaixo.
Obrigado pela atenção... Espero alguma ajuda.
Mensagem 22 de 49
marco.brasiel
em resposta a: Anonymous
Olá Lucas,
O instalador faz download dos pacotes das bibliotecas do Revit e provavelmente houve algum problema com a sua internet ou com o servidor deles.
Você selecionou as bibliotecas que gostaria de instalar? Se você mantiver todas o download pode passar dos 50Gb.
- Se a sua dúvida foi respondida, não esqueça de marcar este tópico como a solução aceita.
- Clique em Curtir se você achou esta resposta importante.
Marco Brasiel - Colaborador da Comunidade de Usuários Autodesk Brasil
Autodesk Community
Marcas (1)
Mensagem 23 de 49
o meu nao ta aceitando alterar as configurações de adminstrador,sabe me dizer como resolver isso?
Mensagem 24 de 49
Estou com o mesmo problema, você conseguiu resolver?
Se conseguiu me diga como.
Obrigado
Mensagem 25 de 49
em resposta a: marco.brasiel
Estou com esse mesmo problema acima. Esse processo funciona mesmo?
Mensagem 26 de 49
Eu estou tentando baixar o programa, pois sou estudante e necessito da ferramenta que vocês estão disponibilizando, porém não estou tendo sucesso.
Não consegui entender o que disse.
Após o download do .exe ocorre tal erro ao tentar executa-lo, mesmo não fechando a janela de conexão entre o site da web e o computador. Não chega nem a abrir o setup onde escolhe as bibliotecas, etc.
**Creio que faltou esta informação no meu post.**
Obrigado... Estou aguardando respostas.
Mensagem 27 de 49
em resposta a: flavio_hera
VocÊ conseguiu resolver esse problema?
Estou com o mesmo windows e não consigo instalar o AutoCad e Revit. Entra em contato comigo por email, caso tenha resolvido, por favor!!
prssilva_@hotmail.com
Mensagem 28 de 49
Eu fiz tudo ate a parte do ok, ,mais depois para ativar o set up onde eu vou?
Mensagem 29 de 49
tentei no RUindows origial 8.1 (32 bits), porém, não concluiu. será que é pelo fato de eu não ter uma placa de vídeo dedicada no meu laptop?
Mensagem 30 de 49
tudo atualizado no windows 8.1, sistema original, internet com a banda toda dedicada para a instalação do REVIT STUDENT, porém, dá o erro de sistema incompatível. meu Laptop não tem placa de vídeo dedicada, tem 4 Gigas de RAM e um processador I5. será que a ausência dessa placa dedicada é o problema? acho que não, pq eu já consegui instalar o AUTOCAD neste mesmo laptop.
grato desde já...
Mensagem 31 de 49
marco.brasiel
O Revit 2015 não é compatível com Windows 32 bits.
http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Se isto resolver o seu problema, não esqueça de marcar este tópico como resolvido.
Autodesk Community
Mensagem 32 de 49
olá,
Desde que atualizei meu windows pra 8.1 não consigo acessar o revit 2014, pois aparece a seguinte mensagem
"Falha na inicialização do aplicativo devido a configuração lado a lado incorreta. Consute o log de eventos do aplicativo ou use a ferramenta de linha de comando sxstrace.exe para obter mais informações".
Como proceder?
Mensagem 33 de 49
o meu deu o mesmo erro, e ainda por cima instalou uns programas tipo; autocad 2016 revet que é bom nada....
Mensagem 34 de 49
Assis.Haubert
caaioted escreveu:
olá,
Como proceder?
Olá @Anonymous,
O teu Windows 8.1 está com todas as atualizações em dia? Verifique no Painel de Controle > Sistema e Segurança > Windows Updade.
Se não estiver, atualize e nos avise. Caso já esteja atualizado, também ;).
Atte.
Cabe lembrar que caso a resposta ajude, ou mesmo solucione a questão, se possível marque o LIKE/GOSTEI nas respostas, caso tenha resolvido/solucionado, marque como "Solução". Obrigado.
Please note that, if the answer helps, or solves the question, please mark the LIKE in the answers, if you have solved/solved it, mark it as "Solution". Thank you.
- Utilize a ferramenta de pesquisa do fórum, a sua dúvida já pode ter sido respondida;
- Use the forum search tool, your question may have already been answered;
- Marque "Aceitar como Solução", caso tenha resolvido o problema. Isto ajudará outros usuários a encontrar uma resposta;
- Select "Accept as Solution" if it has solved the problem. This will help other users to find an answer;
- E clique em "Curtir" se a resposta ajudou.
- And click on "Like" if the answer helped.
Assis Haubert
CAD/BIM Consultant | AEC Technical Specialist | Colaborador CAD/AEC da
Autodesk Community - Português - Cadklein.com | Facebook | Twitter | LinkedIn
Autodesk Expert Elite Alumni
Mensagem 35 de 49
Assis.Haubert
Adelaidelima escreveu:
Olá @Anonymous,
Por gentileza explique melhor a tua frase acima.
  • O "mesmo erro", o mesmo erro relatado por quem? O último ou outro?
  • E como assim "instalou uns programa tipo; autocad...", não deu para entender exatamente o que aconteceu.
  • Qual é a versão que estás instalando? 2015? 2016? Revit Architecture? Revit MEP? Revit..
  • Já tinha o Revit funcionando?
  • Se possível capture uma tela do "erro" e coloque aqui para que tenhamos mais recursos.
Com mais informações talvez poderemos ajudar de forma mais eficiente, ok?
Grato pela compreensão e colaboração.
Atte.
Assis Haubert
Mensagem 36 de 49
analicia.alencar
Olá, eu atualizei o windows 8 para o windows 10, pois no mesmo eu não consegui instalar o Revit que dizia que o windows 8 era imcompatível, então resolvi atualizar para windows 10 afim de conseguir enfim instalar o Revit, porém fiquei frustrada, pois também não consegui instalar o Revit no windows 10, PELO AMOR DE DEUS O QUE EU FAÇO?
A mensagem diz que o windows server é imcompatível
agradeço a atenção.
Mensagem 37 de 49
MUITO OBRIGADA!
PASSEI MUITO TEMPO TENTANDO UMA SOLUÇÃO E ENFIM LI SUA RESPOSTA!
INSTALEI O REVIT 2016 64bits NO WINDOWS 10 TUDO CERTO \O/
Mensagem 38 de 49
Preciso da vossa ajuda! Sempre que tento instalar o revit 2014 dá erro diz que o sistema operacional ñ é compatível. Ñ sei o que fazer me ajudem por favor. Pois meu PC é de 32bits, Windows 8.1.
Mensagem 39 de 49
em resposta a: analicia.alencar
no meu windows 10 nao esta funcionando aprece error 30 na hora que abro a tela inicial.
Mensagem 40 de 49
marco.brasiel
azenaidemalengue escreveu:
Provavelmente o seu problema é com a versão 32bits. Nas especificações, sempre que se fala em Windows 8, se fala em 64bits (ainda não havia o Windows 8.1 na época, mas provavelmente isto não seria problema).
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Autodesk Community
Não encontrou o que está procurando? Pergunte à comunidade ou compartilhe seu conhecimento.
Postar nos fóruns
