We are just trying to understand the benefits of worksets and their pit falls.
I have used them in the past but the only real benefit I've found is the ability to turn on/off that workset in VG. In a model where there is 100's/1000's of elements it's an extra layer of management making sure everything in on their correct workset as well as their correct system.
Is there any advantages when the Revit model is imported into Navisworks?
I look forward to your replies.
We have 3d views set up for Navis exports with filters based on workset. This helps immenseley in Navis, where each system can be isolated and assigned its own visual properties. Worksets do require an additional level of coordination on the designers' part, but they come in handy.
Most users will remember to keep an eye on their current Workset after but a few friendly beatings, but there will always be somethings that inadvertently end up on the wrong Workset; especially if there are a lot of users.
To digress and share some info, I use Schedules heavily in Revit for many purposes, and once such purpose is to help control Worksets. One can customize Schedules to a great degree, and you can use that to control/select elements in your model. For example, on our Projects, we place all of the Ductwork on a single Workset, but often have multiple users working on it. Errors occur, and things often end up on the wrong Workset. So, I have created a Multi-Category Schedule with but a single Field: Category. The Filters are set up to include all Ducting elements but to exclude Lining and Insulation (since they don't independently belong to a Workset). See the image below (expand the spoiler) to see the Filter tab. Finally, I turn off "Itemize every instance" and that leaves one cell in the Schedule. I click that and then click "Highlight in Model" to select all of the elements in the entire Project and I can verify/set the Workset under Properties.
To digress further, I also have this thread in the Revit MEP Wishes forum: Default Worksets
Speaking of advantages, you have mentioned visibility, but that is probably the least important feature. If it were just for visibility, we wouldn't go into the trouble of enabling worksets. Other more important advantages are:
