Revit MEP Forum
Wires and circuits
2 REPLIES 2
tkendrick
449 Views, 2 Replies
Wires and circuits
Has anyone experienced this...
I have several devices on a circuit which has wires connecting them. I now need to do some re-circuiting. When I edit the circuit of the devices, the wires connected to them did not update to the new circuit. So now my home-run arrow and tag shows 2 circuits, the old and new.
Is there any way to fix this, or update the wires, without having to delete them are do it over?
Use this link to tell Autodesk about features you need:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Tags (3)
2 REPLIES 2
CoreyDaun
in reply to: tkendrick
Once the wires are drawn, the are not adaptable and will not change to accommodate the new circuit design, although the information of the wires will be correct. You must redraw the wires: Hover the cursor over a section of wire, hit Tab to select the wire system, user the filter to select only Wires, to delete all of the wiring a little bit quicker.
tkendrick
in reply to: CoreyDaun
Thanks for the info.
Already added this (missed and obvious) functionality to the wish list.
Forma Design Contest
