Revit MEP Forum
ViewCube on sheets
3 REPLIES 3
344 Views, 3 Replies
ViewCube on sheets
I'm putting a lot of 3D views on my sheets and would like to be able to tell which way the view is facing.  I would guess the easiest way to do this is to put the viewcube on the sheet.   Is there a way to do that?
3 REPLIES 3
I have never tried I guess you could make some generic family that would work.  I usually put the direction of view in the title.  If you get that to work lI would love to find out how you did it.
As a work around, I used the "Snipping Tool" and selected the View I wanted the ViewCube from and Insterted that image onto my sheet.   It works, but is a pain if you have multiple views that you want the viewcube in.
I ended up creating a generic anotation family and put that in the 3D view I wanted and that worked out as well as it could.  It would be nice if I could have put it on a sheet.  But this works just the same.
Forma Design Contest
