Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
V/G filters in new view...
2 REPLIES 2
290 Views, 2 Replies
For some reason when I create a new view, I am unable to edit the visibility/graphics, or make any changes to scale, detail level, etc.  It's probably an easy fix, but I'm stumped.
2 REPLIES 2
CoreyDaun
Assuming that you're using Revit MEP 2013 or 2014, the issue is that Views are linked to View Templates which, in turn, are controlling the View Filters. If you want to change the View Filters for this View, you can either create a new View Template and link the View to it, or set the View's Template to "<None>". You can set a View's Template under the View's Properties.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
Got it!  I was on the right track, but this cleared it up for me. Thanks!
Forma Design Contest
