stevemarquiss wrote:
"my system tells me to load the "pipe accessory tags", but when I go to look for them they are no where to be found."
You will have to create one, which is pretty easy. Go to the Application Menu (the big "R") and to New ► Family. In the Annotations folder, just select the "Generic Tag" as your Template, and once it's open, click "Family Categories and Parameters" (the icon with the image of a folder) and select "Pipe Accessories" from the list of Categories. Hit 'OK'. Now all you have to do is place a Label and then configure that Label to report the desired Parameters.
hy, i need help with placing pipes in 3d model in revit 2015. when i select objects and want them to place, all i see is lines, not models, can someone help me with loading pipe accessories family into revit
thx
If you want to have the 3D representation, change the view detail level to fine.
Regarding the pipe accessories, you need to load them, use the Load Family command in the Insert tab, browse in the library after the pipes accessories.
Fábio Sato
Victaulic and Charlotte Pipe have some fittings, the pipes should be set in the project file since they are system families.
Fábio Sato
